1 - 12 of 12 Posts
Hi!
Hope I'm posting this in the right forum.
I recently bought a 42" LCD TV, and I'm looking into hanging it on the wall. I want to do this as simply as possible - that is, I'm not trying to hide wires behind the wall, etc. I merely want a tilt-able rack that will give me enough room between the wall and the TV to plug in cables.
I have looked at wall racks at electronics stores, and the least expensive ones seem to be about $100 to $150. I only paid $200 for the TV! But I have looked online, and I see tilting racks as low as $30. I'm not working at the moment, so I need to keep expenses down.
My question is this: Is there any reason to believe these cheap racks available online are - how can I put it? - so inferior that I'd have to worry about my TV falling off the wall? I mean, it's a pretty basic kind of device, isn't it? Is there any way one can sort them out, quality-wise?
I'd appreciate hearing your advice, or about any experiences you might've had. TIA!
Monoprice sells some inexpensive ones that are good quality. Also, if you have a Sam's Club nearby, they stock Omnimounts that are really nice, starting at about $50. I have used 3 of the Omnimounts and really like them since they tilt and rotate, as well as being very easy to hang the TV on the mount.
There are two things you are going to need to keep in mind:
1. The strength of the mount to hold your tv
2. Using the appropriate type of anchor to hold your rack to your wall.
Make sure to install your mount to a stud in the wall. Sometimes the stud's aren't where they are supposed to be. Believe me, it happens. Especially in older houses.
Tools are available at your local home improvement center that will help you find the studs in your wall. Pay a little extra for one, tho. I had a cheap one that alerted on wallpaper.
That is so true. I have plaster and lathe walls (older house), and regular stud finders go nuts with 'em. I usually use a Zircon metallisensor to find the nails in the lathe/stud. Then have to test with a small masonry bit.
Yeah, I had one of those stud finders. I could never get it to work for me. But I know a guy, as they say. I just have to find a reasonably-priced wall mount, and I'll ask him to help me.
For such a simple mount the only concern you should have is how you anchor it to the wall. Even fairly flimsy thin-gauge steel will be more than up to the challenge. Bolt to studs; you're good to go :T
Thanks! That's what I suspected, but wanted to make sure there wasn't something I was missing. $150 seems like a ridiculous amount of money for a few pieces of metal. But then you begin to wonder how someone else can charge $30, and why the disparity.
Don't worry about the cheaper mounts. I have used the $30 mounts from Parts Express a few times with no problems. My 42" plasma in the bedroom is hung with one of these mounts, going over a year now with no worries. Like everybody else stated, just make sure you mount to the studs.
This is what I ended up ordering to hang my LG 42" LCD. Since I'm not planning to run the wiring through the wall, I figure this will give me enough room to plug and unplug stuff. It was $39 total, with free shipping, and no tax.
http://www.rakuten.com/prod/articul...nt-bracket/231247188.html?listingId=218596339
1 - 12 of 12 Posts
