1 - 3 of 3 Posts
Hi all,
Thanks in advance for any and all suggestions.
I'm looking to temporarily throw my Viewsonic Pro8200 onto a basement wall of drywall. The rest of my basement is painted a dark blue. I will likely build my own screen at some point, make a nice paint mix, and have a good setup. However, for now, I am looking more for a stopgap. (I don't have a paint sprayer, a good way of mixing paints, or really even the time or workspace to build my screen.)
What single paint, that will be rolled onto primed drywall would you recommend for a Viewsonic Pro8200 in a semi light controlled basement with dark blue side walls and a white ceiling? I have done some reading and seen some suggestions about Sherwin-Williams ProClassic Smooth Enamel Satin Extra White, # B20 W 51. Would this be too bright for my projector, especially with the screen going right up next to a white ceiling? Should I try this? get it tinted? or do you recommend something entirely different like silverscreen? or valspar?
Thanks for the suggestions!
Moderator Emeritus
Hi all,
Welcome to HTS! :wave:
What size screen do you intend to have? How far is the PJ from the screen?
Generally, a white screen will only work well if there is no other light in the room during viewing and the room surfaces are dark colors. Even the light from a single candle on a white screen will visibly decrease image contrast/black levels.
You are going to have a problem if your screen is extremely close to a white ceiling. Either lower the screen or darken the area of the ceiling above the screen with dark paint or fabric to absorb light.
Thanks for the feedback, the screen will likely be about 97 or so inches and I will be casting from somewhere around 13-14 ish feet. I have yet to mount my projector so that is flexible, although the room is 18 feet long.
I will do my best with the light control, there is one window in the adjacent room and it is semi-open concept but we will likely get some of those light-controlling blinds and have those down when it is time to watch.
1 - 3 of 3 Posts
