1 - 11 of 11 Posts
The tv is about 4 or 5 years old. The modle number is ws 65315.. I have wavy lines that mess up the picture for the first foot on the top of the screen. It sometimes goes away and then comes back.. everything else is fines its just the lines.. does anyone know whats wrong with the tv? PLEASE HELP i cant take it anymore!!
Thnaks
kevin
Re: Wavy lines on the top of my mistu 65
You may have solder crack rings in the convergence circuit. If this is the case touch them up if any before it's too late.
Or the STK chips are at their thermal edge and loosing stability. Use a mini fan to blow some air to the STK heatsinks. If you don't see the issue anymore by doing this, you'll need a new pair of STKs.
sometimes cracks/solder void is hard to tell with bare eyes. If you have soldering skills simply touch up those solder joints of STK/resistors/yoke_connectors. Otherwise you do need a service tech to help.
You may also try the fan cooling experiment. If issue goes away that means STKs are having thermal stability issue. If so replace STKs or add a cooling system,:heehee:
1 - 11 of 11 Posts
