Weirdness @ 512k samples... whats going on?
1067 Views 4 Replies 2 Participants Last post by  morik
So I am noticing some very odd behavior in REW with the 512k sample measurements... The below is a set of graphs with:
128k
256k
3 x 512k
1M
so 6 different measurements, all taken one after the other, 8 sweeps, -12dbfs
(I did 512, 1M, 256, 128, 512, 512)
What is going on? Why are the 512 ones so off from the others?
(Audyssey is off if that makes any difference)
1 - 5 of 5 Posts
The_REW5_HelpFile said:
Length controls the duration of the sweep signal, specifying the number of samples in the sweep sequence. The default is 256k. Dividing the number of samples by the soundcard's sample rate gives the sweep duration in seconds. The overall duration includes silent periods before and after the sweep. Longer sweeps provide higher signal-to-noise ratio (S/N) in the measurements, each doubling of the sweep length improves S/N by almost 3dB. However, the time required to perform the processing after each sweep will more than double for each doubling of sweep length. If REW is running on a computer which does not have a fast processor and a lot of memory, measurements will be much faster using the shortest sweep length (128k samples), at a small S/N penalty of about 3dB compared to the default. 1GB of RAM and a fast processor are recommended if using the 1M sweep, invalid measurements may occur on computers which have insufficient RAM or processor speed
Its apparent ( from the above text ) that a computers processing power is heavily taxed as one chooses to increase the sweep length .
From the looks of your traces, 256k ( the default duration ) would seem to be the sweep length limit for making valid measurements ( on your particular computer ) .
FWIW, I only see 5 traces in your pic, I wonder if the 1M sweep you made was so "invalid" that REW didn't bother to display it ( or maybe you forgot to include it ? ) .
<> cheers
<> cheers
No, it was there, just pretty much exactly the same as the 256 sweep. (See the little green bit on the far left? It appears again around 62 hz & at the far right if you look carefully... there are 3 blues, 1 red, 1 purple, 1 green)
I was running this on a laptop with:
- an Atom U7300 (1.3 GHz)
- 4 GB of RAM
No problems at all with the 1M sweep...
Okay, I'm stumped .
I would simply chalk it up to "digital burping" of some sort and avoid that sweep length .
<> EarlK
Okay, I'm stumped .
<> EarlK
Well, and the other day when i was making my first graphs (from my other post), I think I was using 512k sweeps... and they came out relatively fine I think...
1 - 5 of 5 Posts
