1 - 5 of 5 Posts
G
What cable would I need if I have an m-audio mobile pre usb sound card, ecm8000 mic, and a DSP1124 so that I can download the REW calibration information directly to the feedback destroyer? I read in the REQ faq that a usb to midi cable could be used if using the built in sound card on a computer but I was wondering if the M-Audio Mobile Pre already has a midi out port. Thanks in advance
But is there something cheaper that can be used other than that $40 cable from amazon? I was wondering if the mobile pre already had a midi out port
I don't think the Mobile Pre has a midi port.
The cheapest route is to enter the filters by hand. It only takes seconds. I've never owned a midi cable myself. Not because of the cost, but because I can enter the filters before you could connect up the cable...
1 - 5 of 5 Posts
