1 - 11 of 11 Posts
Are you talking in reference to acoustic stuffing used in speaker enclosures?
Matt
It it my understanding that it means 100% of the internal volume of the enclosure filled with acoustic stuffing.
Here is an interesting article on the subject.
http://sound.westhost.com/articles/boxstuff.htm
Matt
The problem is that the term isn't standardized. I'd consider maximum fill to be 1/3 the volume of the box. You shouldn't be leaving no gap for the voice coil to breath in.
My problem is that a percentage does not suggest density. Do I want the fill to be fluffy? Do I want it to be stretched as fine as possible? I could jam four shredded pillows into my box or one.
Good point!! :T
I pack in 2.5 density rockwool for fill and then cover it with a sheet. My cross braces are usually a third into the box so I just fill it up to that point. Don't compress it too much though. You are filling the sub not compacting the sub.
Yet another good point :T :rofl:
I'll keep this in mind if I ever need to stuff an enclosure.
In my experience, "100% stuffed" means using 16 ounces of non-compacted fill material per 1 cuft of enclosure volume.
Agreed. One pound polyfill per cu.ft. = 100% fill. If the sub has a vent pole then it will need a couple of inches of clearance between the back of the sub and the polyfill.
1 - 11 of 11 Posts
