im new to custom speaker building so i need some advice
iv chosen a 12" Woofer, Poly Mica Cone, 4 Ohm, W-1244
with these specs Steel Frame
Poly Mica Cone, Rubber Surround, Vented, Bumped Backplate
Hole cut-out: 11"
Depth: 5-3/16"
Voice Coil: 2"
Magnet: 40 oz
Impedance: 4 ohms, Re: 3.6 ohms
Power: 150 watts RMS, 300 watts max
Response: 18-5000 Hz
Sensitivity: 87 dB, 1 watt, 1 meter
Le: .60 mH, Fs: 33 Hz, Vas: 4.22 cu. ft., Qms: 3.30, Qes: .86, Qts: .68, Xmax: 5mm
for my 5 surround speakers center, fronts, sides
along two tweeters per
Dayton Audio AMTPRO-4 Air Motion Transformer Tweeter 4 Ohm
an too be run off a 2 Way Crossover, 12 dB/Octave, 2000 Hz, A-1300
powered by a set of Crown XLI800 Two-channel, 300W at 4Ω Power Amplifier
for the center, fronts, sides
my problem is the software im useing box port design 2 says for optimized sealed profile system q 500 -9cubic resonant fq 24hz -3dbs at 37hz an i have no idea how to make -9cubic feet for a box but i do want the system q value of 500 for tight response
my custom profile is
system q 1009
3.52cubic air volume
resonate fq 48hz
-3dbs at 38hz
is that bad or good
12.75 wide 48tall an 15deep
i plan to have 2 Dayton Audio RSS315-PR 12" Aluminum Cone Passive Radiator
for low end tuned at 17.7hz
is this good or bad
any advice
Hole cut-out: 11"
Depth: 5-3/16"
Voice Coil: 2"
Magnet: 40 oz
system q 1009
resonate fq 48hz
-3dbs at 38hz
is that bad or good
is this good or bad
any advice
