I'm going to start off VERY basic to make sure no one is left behind so be patient.
Reproducing recorded music is the last process in a chain of events that starts with the artist/musician and ends with our brains interpreting the compressions of air produced by speakers as sound. How faithfully the sound we hear matches what was originally played/sung is how most determine the quality of the reproduction. We all want the experience in our living rooms to be as close as possible to what was produced in the recording studio or concert stage. Understanding how that happens in the systems we own will go a long way to finding the best components for our given tastes, capacities, and budgets.
The sound we hear at home is produced when the driver cone(s) in a speaker move(s) back and forth, compressing air. If the motion occurs 261.626 times a second we hear middle C. We need to know just how that cone is placed into motion. What effect does the quality of the components have on the accuracy of the motion and therefor the quality of the reproduction. I’m sad to report that this involves an understanding of some basic to intermediate concepts in electricity.
The thing that moves the cone of a speaker driver is the voice coil, a coil of wire inside the driver that rests in the magnetic field of a doughnut shaped magnet. When electric current passes through the voice coil it moves and, being attached to the cone, the cone moves as well. Reverse the direction of the current flow and the coil and cone reverse direction as well. Do that 262.626 times a second and – viola – middle C.
… but what is this current stuff? …
Current is the flow of electrons in a conductor. The wire in the voice coil is a conductor – copper. Other conductors are gold, silver, iron, aluminum, and mostly any metal. Ceramics (among other things) can be conductors, too, but that’s another subject. If a specific number of electrons called a coulomb (very big number you that don’t really need to know) pass a particular point on a conductor in 1 second we call that 1 ampere of current.
I = Q/t … Where I is current in amps (ampere), Q is charge (electrons) in coulombs, and t is time in seconds.
Now that we know what current is, what makes it happen? It’s good to think of current flow a wire similar to water flowing in pipes. To get water to flow we need pressure like from filling up a barrel. Water will flow from the bottom of the barrel if a pipe is attached and continue at a diminishing rate as the barrel empties. The height of the water in the barrel produces the pressure by virtue of the weight of the water above the pipe. The counterpart in electricity is EMF – Electromotive force – It’s measured in Volts and is commonly referred to as voltage. It is the “pressure” in an electrical circuit.
Back in the barrel example, the amount of water that will flow will be determined by how big the pipe is in diameter. The smaller the pipe’s diameter the less water will flow for a given pressure (water height). A smaller pipe exerts more Resistance to the flow than a big pipe does. There is a counterpart in electricity that is called (are you ready?) Resistance. Resistance is measured in Ohms, that’s right, the same thing that speakers are rated in. You may have made the connection by now that somehow the amp creates EMF (voltage) that causes current in the speaker voice coil wire and is somehow affected by the speaker’s resistance. If you did you’re on the right track but we left off one more important item – Power – and that’s measured in watts. Put all four of these - V(voltage),I(current),R(resistance), and P(Power) - together and we have the four cornerstones of electricity called Ohm’s Law and that’s where we go next.
