Will do got a Oppo BD83 to go with it:bigsmile:
You lucky Santa... :bigsmile:
I just got the 600m and been told to break in 150 -200hrs before calibration-- what pupose does this break in have? what about burn-in when watching ESPN or CBS - no problem?
Congratulations on one of the very best there is!
* Break-in will warm up the elements that are part of the plasma panel in a controled fashion.
It is exactly to prevent eventual burn-in.
So, for the first about 200 hours, don't crank up the Contrast & Brightness controls, set them at about half way.
Then, after that 200 hours, you can set the video parameters to your preference.
Or what is best is to use a calibration disc to adjust these; Contrast, Brightness, Sharpness, Color & Hue.
A plasma set needs that break-in period, where all video parameters are decreased to about half way from their position, so that at the begining, your TV gets comfy without unecessary pushing of the Contrast & Brightness controls, to prevent possible burn-in in its plasma components.
Makes any sense?
Bob
