1 - 20 of 25 Posts
I looked up the top product of several different companies with relative size, and here they are.
Velodyne DD-12, HSU ULS-15, Polk Audio DSW4000, SVS PB13 Ultra.
Thats the number crunching part, does anyone have any experience with these subs to compare it with?
I just read that M&K will be re-opening there business and starting there classic line-ups with newer updated lower build quality line-ups.
IF so than...my dad used to own an M&K and said the quality was unparrelled when he was searching for subs, and purchased a 1000$ one at the time around 1998.
Is M&K a good place to build my subs around?
And for now, lets look at pure quality of a system, and avoid money...lets say i have near unlimited funds for a system...within reason...and for me reason lets say is...30K max total invested in a system.
Where should I look for sub building? I think multiple subs will allow me to have good bass coverage throughout the room.
I will turn down the gain i think on all subs to not have toooo much bass.
M&K makes great subs. I own the MX350, which I need to sell, and it sounds better than any other sub I've ever heard. They don't have the output of modern subs as they are based on a design that was last updated in the early 2000's before high excursion woofers became commonplace. But given a choice I would buy their subs hand over fist over velodyne and I did. The company was officially open again last year, but haven't heard much from them. Their webpage welcomes a new US distributor so maybe they are getting close.
I own a SVS PB13 Ultra and have owned a few others. I can say that the PB13 ultra is one of the best subs for the price that you can buy. It still amazes me as to how low it can go without distortion and the look of it is plain amazing. For a signal 13" driver to be able to go below 15Hz @around 100db is just crazy.
Cool cool, thanks for the feedback.
And by sub building i meant, what company should i build my multiple sub set-up around.
I own a Velodyne DD10 and I am very happy with it. It took some time to setup but it was worth it. I just bought a Definitive Technology Trinity and I am speechless. I paid about $2000 for the Velodyne and about $2900 for the Definitive, it is bigger but also gets lower than anything that I have ever heard.
You may also like to consider getting custom built subwoofers, we can build products with competative performance for the price as many others, and we can also build very unique, both looks and performance, products that simply have no equal.
You dont always have to "build around" available products, the products can be built around you!
Ps; We do more then just subwoofers, and more then just speakers....
Out of the ones you've mentioned I would go SVS. Have you looked into Epik subs? They use good designs for their subwoofers and I think you get a bit more bang for the buck with those. They're just larger than the subs you mentioned.
At the risk of reading too much into this, I take it you're more interesting in accuracy than brute force.
Much depends on the room. From what I've been reading, the use of multiple subs does more to smooth out room anomolies than just about any other solution. Four subs seems to be the optimum, fewer and there's less control, more and you don't gain much.
I think we need to consider practical solutions. As much as I'd love to put 4 Ultras in my HT, since is it a mid-sized room (16x20x9), I think it would be overwhelmed. What size space do you have?
I have an SVS PB12-NSD which I love. I'm seriously considering buying an SVS AS-EQ1 subwoofer EQ device. It looks like it would be the best use of my money to make my system sound even better. I've never REW'd the room, I think I'll do that first to determine how much correction is needed.
While you're dreaming, look at the Rhythmik subs. They're now being sold by Ascend as well. They seem to be very tight and accurate.
Doug
Not sure you have the right numbers. If you do a search for either the great Ilkka's subwoofer test results here on HTS or craigsub's test results elswhere, preferably both, you'll find some numbers on SPL and distortion vs. frequency, which is much more relevant than the numbers you've posted, other than price.
Have to admit I have no experience with any of these subs, but I do have a clear favorite based on "bench racing." :devil:
Any fans here that support sunfire subs :) ?
Sunfire makes a good sub but they are a bit over priced. I have been a Carver fan for many years and owned a Carver Receiver for many years.:T
For the price, Hsu looks like a very good subwoofer. I don't have experience with that particular Hsu sub, but I have the STF-2 in a fairly large area. It is very satisfying for my setup, so I imagine the 15" Hsu would be phenomenal. I already get yelled at for playing movies too loud when the explosions hit, I could not imagine going with the big boy from Hsu. Get two or the get the Hsu MBM to go with it and I would say you would be very satisfied. Adding the MBM should still keep you under the price of the more expensive subs you listed.
1 - 20 of 25 Posts
