What type of gating is appropriate to measure loudspeakers with? Say you are 3ft away from your elevated and in the center of the room speaker. You gate is set at 6ms. Should you use hamming, Tukey, flat-top, etc... ?
Thanks,
Dan
Truth is that's a little over my head, but I believe to at least some extent that's going to depend on the specific measurement you're lookig at.
Those that know more about that than I do will be by shortly ...:huh:
Discussion Starter #4
Thanks Gents! Bruce, do you have any understanding as to why you use what? I've done a bit of research on it and couldn't find anything that was obvious or stated in layman's terms. It was all for mathematicians and engineers. There's a bit on it in the REW help files, but not with regards to gating.
Thanks again,
Dan
