i heard it is better to fill the voids/imperfections on the box with bondo or a type of elacstic based putty and sanding smooth.
could anyone confirm this?
also i have to fill in a nice little hole on my box im going to seal it from the inside and what do i use to make it smooth? i would have to fill the whole with something before i lay down my veneer.
my box testing it out seems to slide alot i have hardwood floors and when i turn the volume up it seems to slide and move alot.
would just any regular rubber feet work?
