1 - 13 of 13 Posts
OK no problem :)
1: 15" Audiobahn Immortal AWIS15J: available only:
fs 45hz
vas 1,66 cu ft
qes 0.53
qts 0.493
xmax 16.5mm
97db, 2200W RMS
2: 15" EARTHQUAKE SOUND DBXi15: available only:
fs 21hz
vas 3.21 cu ft
qes 1.13
qts 0.45
xmax? xmech 44mm
88db, 750W RMS
3: 18" American Bass HD18D2
fs 27.37 hz
vas 5.23 cu ft
qes 0.375
qts 0.341
xmax 45mm
91db, 1500W RMS
(qms-3.77;L-7.87Mh;Bl-29.12;Mms-486.2)
I want the biggest SPL from about 13hz. Subwoofer will be used only for region 13-30hz paired with velodyne spl1000 in range >30hz.
When I look at WinIsd, number 3 looks the best. Any other driver from ebay in that price?
Thanks
yes there is a huge peak in LLT and around the peak, frequency response drop off significantly.
So, which driver? I was looking for RE AUDIO MX 18 D1 and Kicker S18X2.. Any other?
they model very similiar. in LLT 13hz ported 500litres there is a huge peak at 13hz, but good spl in both cases - from 116 - 119db. i will probably choose BTL because kicker is not available on ebay now. kicker has more mms (around 800-900!?), Fi is "only" 340.. and bigger cone area, because its squared woofer
1 - 13 of 13 Posts
