You won’t be able to use an outboard equalizer for your center channel unless you are using outboard amplifiers. If you are, I’d go with the balanced miniDSP version, not unbalanced, as the unbalanced doesn’t have much headroom. You can use one channel for the center and one for the sub.
If you don’t have outboard amps you will only be able to EQ the subwoofer. In that case I’d go with the BFD. You can get the 1124 used pretty cheap. The current model if you’re buying new is FBQ1000.
