Hello,
I consider to get a new multi-channels receiver. It has as an EQ function with a possibility of 10 filters per channels with the following values:
BAND 1 Freq :20Hz - 80Hz, 1Hz Step Default 40 Hz
BAND 2 Freq: 20Hz - 80Hz, 1Hz Step Default 60 Hz
BAND 3 Freq: 81Hz - 140Hz, 1Hz Step Default 100 Hz
BAND 4 Freq: 81Hz - 140Hz, 1Hz Step Default 120 Hz
BAND 5 Freq: 141Hz - 200Hz, 1Hz Step Default 160 Hz
BAND 6 Freq: 1110Hz - 1550 Hz, 10Hz Step Default 1300 Hz
BAND 7 Freq: 1560Hz - 2000 Hz, 10Hz Step Default 1750 Hz
BAND 8 Freq: 2.1kHz - 8kHz, 100Hz Step Default 4k Hz
BAND 9 Freq: 8.1kHz - 14kHz, 100Hz Step Default 10k Hz
BAND 10 Freq: 14.1kHz - 20kHz, 100Hz Step Default 16k Hz
Q : 1 - 24
Gain : -12dB - 0 - +3dB
I could take measures with my UMIK-1 and ask REW to suggest eq. Would I try to best match the equalizer among the choices offer in REW or use the generic ? In this case it should be "Emotiva UMC-200 filters set" even if the amp is not Emotiva.
Also, is it possible, and if so, what is the best way to take mic multipositions measurments whith REW (to imitate Audyssey, YPAO or Dirac Live ) to calibrate a 5.1 system with this receiver EQ?
Q : 1 - 24
