Out of curiosity which of these drivers listed below would work best in a Mid-Bass enclosure tuned anywhere from 25 to 50HZ. Looking to see which would supply the most mid-bass energy.
I do know there are other drivers out there more suited to this application but a friend has good low bass but not a lot of mid-bass and these are the drivers I have available. I did mention to my friend that Acoustic Elegance has some great mid-bass drivers or we could go with a pro-driver but he would rather use what I already have.
ACI SV12 (already pre-loaded in WinISD)
Impedance: 4 ohm
RMS Power: 350 watts (system power 500 watts)
Sensitivity: 90dB
Fs: 17.5Hz
BL: 8.9 Tm
Qms: 8.35
Qes: 0.41
Qts: 0.395
Vas: 250 liters
Cms: 1041.67
Mms: 99 grams
X-max: 12.87mm peak
VC Ø: 2" (51mm)
VC Height: 31.75mm
Air Gap Height: 9.652mm
VC Inductance: 1.45mH
VCR: 2.97 ohm
NHT Sub2 (WinISD download below) will be used as a pair dues to the 9.58 ohm config. wired in parallel.
Re: 9.58
Fs: 21.5
Qms: 2.952
Qes: 0.444
Qts: 0.386
Vas: 103.84 L
Cms: 0.000561
Mms: 97.8
Dia: 215
BL: 16.87
Spl: 85.47
Zmax: 73.2
Sd: 0.03631
Xmax: 13.0
Hg: 8.0
Hvc: 34.0
Audiopulse Axis 12" QVC (WinISD download below)
12″
Qts 0.33
Re (series) 4.7 Ω
Fs 25 Hz
Cms 125 µM/N
Vas 44 lit
Mms 310 g
BL (series) 26.2 Tm
Sd 0.050 m²
SPL 85.2 dB
Xmax 30 mm
Just really need something that will work like the HSU Research MBM. He already has a EP2500 so we can use the HPF on it at 30 or 50HZ, whichever would work out best. We will only be using 1 channel of his EP2500 as the other channel is already in use. I also picked up a Reckhorn B-1 and ED EQ.2 so we could use one if need be.
I was almost going to not include the Audiopulse due to it's power demands but in a high tuned ported enclosure and the QVC giving me flexibility to wire it up 1 channel for the EP2500 should work out well.
My buddy wanted the Audiopulse as a possibility too since he really likes it after hearing my test boxes.
I can use the ACI SV12 in a pair as well if that would work out good.
I plan on using them in a ported alignment as he has a pretty big room and I want it to be as efficient as possible. This MBM will be crossed over at probably 100 to 120hz depending on what his processor allows.
If you could list which drivers you think would work best then your second choice I would appreciate it.
Thanks.
Impedance: 4 ohm
Sensitivity: 90dB
Fs: 17.5Hz
BL: 8.9 Tm
Qms: 8.35
Qes: 0.41
Qts: 0.395
Vas: 250 liters
Cms: 1041.67
Mms: 99 grams
X-max: 12.87mm peak
VC Ø: 2" (51mm)
VC Height: 31.75mm
VCR: 2.97 ohm
Re: 9.58
Fs: 21.5
Qms: 2.952
Qes: 0.444
Qts: 0.386
Vas: 103.84 L
Cms: 0.000561
Mms: 97.8
Dia: 215
BL: 16.87
Spl: 85.47
Zmax: 73.2
Sd: 0.03631
Xmax: 13.0
Hg: 8.0
Hvc: 34.0
12″
Qts 0.33
Re (series) 4.7 Ω
Fs 25 Hz
Cms 125 µM/N
Vas 44 lit
Mms 310 g
BL (series) 26.2 Tm
Sd 0.050 m²
SPL 85.2 dB
Xmax 30 mm
Thanks.
