Hey Gang,
I find I do most of my music listening at the computer, so I'm going moving on up to a pair of wall-mounted Magnepans (flat panel speakers) and a sub, but which one? The Magnepans only go down to a rated 100Hz (120 might be more accurate) so the sub needs to be flat to about 150Hz. I have a pretty typical set-up, so a large cube does not fit under the desk. If any dimension is 10" or less, I can make the sub work. Prefer sealed for this application, don't need either high SPL or deep extension. Just tight & fast & no bloat. A -3dB of 30-35 Hz would be fine.
Ideas? I'm hoping to stick under $500. NHT has a unit that would appear to fit the bill. Thanks.
JD
have you checked into any used Sunfire subs. They are small but good. Most subs that small will sacrifice both sound pressure level, and, sound quality. Several companies sell smaller subs with 8" drivers, so, you could look online. Let us know what you find. Have fun, Dennis
