I’m sure you can find something here: Google USB MIDI interface Windows 7 64
Not sure what the point is, though. You can enter the filters by hand in less time that it takes to connect the cable and enable the feature...
Thanks. Actually I had tried that before posting the question.I’m sure you can find something here: Google USB MIDI interface Windows 7 64
Thank you for the update! I just had the same question and conveniently came across your post on the first pageUpdate - I wound up going with the M--Audio Minisport UNO. Apparently just a few weeks ago they released x64 drivers. Anyway I just wanted to report that I installed the latest drivers from their web site, plugged in the UNO to the USB and it recognized the drivers and was ready to use in a few seconds. No muss, no fuss. Then I verified I was able to successfully write filters to the BFD. Nice! Glad I finally motivated to get the MIDI interface and update my BFD to v1.4 of the firmware...
Great. I stressed over this a bit because I know it can be a real bummer to buy a device and not get the drivers to work and mess with it for hours etc. So I just wanted to know going into it that whatever I was getting would work. And indeed it went real smooth. Just be sure to use the latest driver from their web site. I ran their driver installer BEFORE inserting the device for the first time. I'm so glad you found my post helpful. Thanks for letting me know.Thank you for the update! I just had the same question and conveniently came across your post on the first page![]()
