So, everyone keeps telling me that professional subs are preferred to car subs for dj systems, I'm trying to understand why that is. For the sake of this conversation, let's take the boxes out of the picture, as I understand that a bigger box will give you a lower tone, which is why a car box wouldn't work for a dj system.
It seems like the purpose of any sub is to move air, so the two most basic needs are surface area, and throw depth, combining to give you the maximum amount of air the sub can move with a single wave, and therefor the loudness. The other factors seem to be the rated wattage, and even more importantly the sensitivity, which will give you more movement of air for your wattage. Also the impedance comes into factor with a lower one letting you chain more speakers together for more bang for your watt.
It looks like car subs and dj subs have comparable SPL, volume of air pushable, with the car subs typically having a higher wattage, and lower impedance.
So, why, after all of this, is a dj sub with the same spl, wattage, and impedance better than it's car sub equivalent?
As a follow up question, why aren't pro subs then used in cars?
