The center channel (2, 4" drivers) I currently have does not match the front bookshelf speakers that I am using ( 1, 5 1/4 driver). I need to over drive the center volume by 5 to 6 db's from the calibration point that was setup with the receiver's calibration sequence inorder to hear the dialogue properly. Is this due to the mismatch with the center and front bookselves? Everything is 8 ohms.
Well, I have to boost the center channel (Dynaudio Contour S C) with +4 dB when calibrating against the fronts (Dynaudio Contour S 1.4) using a Radio Shack meter. The speakers are designed to work together (see specs below). The fronts and center are powered by two seperate Rotel RB-981 amplifiers. For the center I use the right channel (leaving the left idle) and the amplifier is not mono-bridged. Listening distance is identical as are the speaker wires. I don't have a clue why I still have to boost the center. Tried switching amlpifiers but it did not change anything....
Contour S 1.4 Contour S C
Sensitivity
(2,83 V/1 m) 85 dB 86 dB
IEC Power Handling 160 W 150 W
Impedance 4 Ohms 4 Ohms
Frequency Response (± 3 dB) 41 Hz – 25 kHz 65 Hz – 25 kHz
Box Principle 2-way, bass-reflex 2-way, bass-reflex
Crossover Frequency 1900 Hz 1400 Hz
Weight 12.6 kg 10.3 kg
Dimensions (W x H x D) 188 x 404 x 360 mm 7.4 x 15.9 x 14.2"
490 x 160 x 303 mm 19.3 x 6.3 x 11.9"
