It's because they are Helmholtz resonators. Using multiple ports is similar to a single larger port with the same surface area. Larger ports = longer lengths for any given enclosure volume and tuning frequency.
You are correct there. I typically try and use 15-16 sq in of port area per cubic ft of air space. It keeps the air velocity down to a min.I wouldn't ever sacrifice tuning frequency for a shorter port, unless onyl absolutely necessary. Another hugely important note is that the cross-sectional area of the port will allow enough airflow for the sub(s) of the given design. I think air velocity should not exceed 30 m/s. Anybody correct me if I'm wrong here...
Not necessarily - some 15" drivers work quite well in a relatively small (~2 cubic feet) box. However, the efficiency is pretty horrible - expect to use a 1kW+ amp to get the most out of 'em.With a good 15 your going to need a huge cabinet.
I'm sure Moonfly was referring to ported, it would be a challenge to port a high excursion 15" driver in 2 cu.ft.Not necessarily - some 15" drivers work quite well in a relatively small (~2 cubic feet) box. However, the efficiency is pretty horrible - expect to use a 1kW+ amp to get the most out of 'em.
Yeah I was talking about ported. Even something like the AV15-H, which is directly targeted at small enclosures with its design, still requires in the order of 150 litres volume to become an EBS sub, more for a true LLT. Considering the same driver can work in only 40 litres sealed, then 15" LLT's or -3/-6EBS subs (like the SVS Ultras) are very very hard to get into tiny cabs, even external porting wont make the cabs tiny.I'm sure Moonfly was referring to ported, it would be a challenge to port a high excursion 15" driver in 2 cu.ft.
I was modeling a dayton 12in hf in a 4.2ft³ and wanted the look of the svs with 3 ports. I like how proportional the box looks in regards to the driver and 3 ports.In respect of BKnights comments, I had a play with WinISD last night, and managed to get port lengths to around a meter each with a 15" driver, its still a lot for a box though, and I think a Sonotube would be the only realistic way to build an SVS Ultra type sub with a 15" driver.
Thanks I was planning on using the 4 in flared ports from PE which can be up to 17 in long.Ill try take a look at the model(s) tomorrow and see if I can come up with anything of use, if no one beats me to the punch.
