I was setting up for a 4th round of measurements and the program kept throwing this error and wouldn't recognize the mic.
Typically I plug the mic into the laptop and start Rew....and a window pops up 'Rew has found Umm-6 mic, would you like to use it?' And it's right after saying yes that it now throws and error and doesn't work.
I've rebooted, I've changed preferences, and I'm still stuck.
Any ideas?
Thanks
Sent from my iPhone using Tapatalk
If the mic is set up to allow applications to take exclusive control (tick box on the Advanced tab of the properties for the input) some other application may have claimed it, so REW can't get access. Untick that box and/or try and find what other application is using the mic.
This is strange....I've unclicked the exclusive setting and it still will not work.
I've tried "Restore Defaults", disable and re-enabling, and changing the default format from CD to DVD.
Same error.
Any other thoughts???:dontknow:
Thanks,
M.J.
Success! No idea why that fixed it, but it did! Thanks!
One last question...should it be 2channel, 16bit, 44,000 or 48000Hz?
