1 - 9 of 9 Posts
For some reason I'm getting Higher Freq Extension out of my single (KEF Cube 2 )Sub, ...than one or even both of my (RSS 315 HO-4) Subs ?
I thought maybe the 2 RSS's were canceling out at higher freq ,so i compared using just (1) against the Kef in the same Left corner as the Kef , but the Kef still extends Further up ??
These Dayton Subs are know to extend fairly high , so it should at least keep up with the Kef in the same position no?????
GRAPHS:
-The 2 Purple are the Kef at 80hz crossover and 200hz crossover
-And the 2 Green is the (1) RSS315 with 80 & 200 crossover
What is the RSS 315 HO-4 powered with?
A Dayton SA1000.
When i took graph ,i used only 1 of the 2...I used the one in the same corner as the kEF just to compare FR.
2 together have a 4 ohm load ... so 1 should have 8ohm load ?
Anyone with Dayton RSS315 HO-4 in a ported subs that has measured their FR to see how HIGH they extend ??
Yes , but should be exteding at least as high as the little Kef Sub for better integration with small Sats
Have u seen the graph at the beggining of the thread.
1 - 9 of 9 Posts
