hi all
is it possible that the samsung k950 can do 7.1.4 sound
using a additional 2 speakers i was reading on amazon that some guy said
Has anyone tried to (or can you) add additional speakers to this successfully? as an example, add Radiant 360 R1's to sides of room?
Answer:
The installation manual says it can connect up to a Samsung multi room audio system. It looks like you connect a wifi enabled device that controls some other speakers. If you can download the manual from Samsung site, it has some explanations.
can anybody please verify this is correct
if so what do i need to buy and what speakers would work very well with the soundbar thanks
Answer:
