1 - 2 of 2 Posts
not sure if this is a windows 10 issue or what.in the past ive not had an issue with the program.on to the core of the issue.the driver parameters specifically.driver size,and xmax change.when I save a new driver.when I was calculating a bandpass box.the driver wont physically fit.i enter 8.54 inch for overall speaker diameter.it always changes it back to 8.being one measurement of the box is 9.5 inches.assuming 3/4 mdf is used.the internal dimension becomes 8 inches.well an 8.54 inch overall diameter driver isn't going to fit.
I will include the winisd file
1 - 2 of 2 Posts
