1 - 3 of 3 Posts
hello everyone first of all thanks for allowing me to join and learn from you all. I have installed winisd and made an attempt to load some of the download-able files that are in the sticky but winisd is wanting a .wpr file extension while it seems the files in the thread are .wdr have i totally missed something here? thanks for all youre help! shannon
Hi,
wdr files are the driver parameter files, while wpr files are subwoofer design plot files. In both cases the files should load and run in WinISD, so if they wont there may simply be a glitch, possibly from your install.
It might be worth re-installing the program if its the first time you have run it. Out of interest, which file are you trying to upload. If you cant get it to work you could always input the drivers details yourself and save the file to your system. I know its a bit more of a pain, but if you cant get files to auto load then its an option.
1 - 3 of 3 Posts
