Win7 64 Bit Compatibility?
1702 Views 3 Replies 3 Participants Last post by  Kenneth R.
Forgive me if I've overlooked something obvious. I have tried searching for this issue with no luck.
I am trying to install REW onto a machine running Win7 64-Bit. I get stopped with the error below.
Any thoughts?
Text Font Line Screenshot
And for the sake of making this findable by search if ever there is another with this problem, the error text reads:
The version of this file is not compatible with the version of Windows you're running. Check your computer's system information to see whether you need an x86 (32-bit) or x64 (64-bit) version of the program, and then contact the software publisher.
1 - 4 of 4 Posts
Thats a strange error. I have win7 64bit and it installed just fine. Im sorry I dont really have an answer but I know it works.
I figured it out. Strangely, when I click on the link from the download page, it is downloaded by my dl manager in Chrome - Flashget. It saves it with the filename "27319d1296393625-downloads-page-wizardinstallv5.exe"
I did a right click and save target as... and it saved it as "wizardinstallv5.exe". Now it has the appropriate icon, and it runs just fine.
glad you got it, was going to say i also managed on win7 x64
1 - 4 of 4 Posts
