1 - 8 of 8 Posts
Hi, i have a problem with WinISD Alpha. I'm pretty sure there should be a drop down menu for the user drivers i create but there isn't. Does anyone know whats going on cos the software is useless to me unless i can put in my own drivers...
Thanks for any help,
Purp
The drivers you input are added into the normal drop down menu. Once you have input your data, make sure you store the data then close the input window. Then open a new model, and your driver(s) will be in with the rest of them. It can help if you give your files a distinctive name or use CAPS so its easier to find them.
Hmmm. Well I have to totally close it and then re-open the program. It happens on both Vista Ultimate and XP pro for me. I'm using 0.60a1. Different versions maybe? :huh:
1 - 8 of 8 Posts
