1 - 5 of 5 Posts
I'm somewhat new to the program. Can someone double check my work and give me suggestions on how this plots out.
If i were to tweak it, what should I change?
260562
TC Sounds Neo Axis 12" (RED)
TC Sounds 3000 12" (GREEN)
IAS Prototypes 12" (BLUE)
Passive Radiator modeled is 4 FT^3 and 15" TC Sounds VMP (Washers added to achieve FS: 14hz)
My goal is to go as low and loud as possible 25hz and below with equipment that I have for Home Theatre use.
How will this sound in theory? How can I tweak the model to optimize the curve.
p.s. The vented curve is specially for a dual 12" enclsoure I already made for my vehicle, 4 cubes @29hz (6" aeroport) so we can disregard these curves
remember that this is a simulation in an anechoic chamber , which is far removed from the Real World of a closed environment.
I prefer to use Hornresp.net to model enclosures. Check out the thread on diyaudio.com.
  • Like
Reactions: kastlez
No problem guy!
1 - 5 of 5 Posts
