1 - 5 of 5 Posts
I'm remodelling our basement and turning it into a media/entertainment room... There's a small closet about 15' from where the equipment is going to be and I'm thinking about building an LLT sub in there in the future. It's about a 20' run end-to-end and far more convenient to run speaker cable to the closet than adding a power outlet in there.
So, what gauge wire would be best for a run of this distance? I figure I should plan for a 2 Ohm load and about 1000 watts depending what I'll build so I won't be too limited (no exact plans yet). It's not that big of a room and I don't really crank it so I can't imagine needing more than 1k of power to run this thing, maybe an ep1500 . I'm wiring the rest of the basement w/14 gauge in-wall for the rest of the speakers (full 7.1 setup)... Is 14 gauge enough for the sub too for a 20' run?
Thanks,
-Todd
It wouldn't hurt to run 12awg or even 10awg wire. Given the load that the sub will demand its better to have a thicker wire than not enough. 14awg is pushing it in my opinion.
By the way, Welcome to the Shack!
Thanks...
You're right, I guess it's just not worth it to save a couple of bucks to run the thicker wire.
I've been here at the Shack for a while, just never had to post since there's already so much info here!
Great place this is...
-t
1 - 5 of 5 Posts
