1. What size wood screws would you use to put Elemental Designs 19ov.02 woofers into 3/4 edf and foam weather stripping?
2. What thickness and width of weather stripping would you use on the endcaps that were cut for flush mounting (about 1 inch lip)?
3. How do I wire up the dual 2ohm woofers to 4 ohms and then how do I connect them together to run at 8ohm... I heard that was possible
4. If my amp puts out 1300w at ohms in bridged mono, will each woofer get half of that?
3 of the questions are short, one is long I guess but I really want to finish this weekend before I get killed for taking over the kitchen with these tubes.
