1 - 5 of 5 Posts
It's going to be new construction for a home I'm building.
I have a bunch of stuff I want to hook up.
6 rooms will have 2 speakers in each room,thats (12 wires ) that are ceiling mounted, each room with have a wall mounted IR receiver (Buffalo Electronics Buffalo IR-250 In-Wall Insert IR Repeater) All of this needs to go somewhere and be hooked up to a Russound 6.2 speaker selector.
Then there will be one RG-6 cable run to 7 rooms each one of these run will come from a Video Distribution System amplifier.
7 rooms, each will have a RJ45 CAT5 Network plug
So, I will have a DSL modem, a router, 8 IR repeater, 8 speaker selector, 7 input video amplifier,4 camera video server, two phone jacks .
Just what should I do to have a place for all this to go and be hooked up?
I really think a wire closet just might be the thing to do, you guys have had this problem,
I sure would like to hear some ideas.
Thanks:T
Definitely a wiring closet, and while the walls are open and wire is cheap, 2 runs of cat5 min, cat6 would be better. The future is digital, and cat can be used for vid distro.
I believe your right, about the future being CAT5
1 - 5 of 5 Posts
