Pioneer Eliete Vsx-53
PowerAmplifier Design Advanced Direct Energy
Channels 7.1
Power Output: Watts per Channel 110 x 7 rated output power per channel @20Hz to 20kHz, 8 ohm (770W total)
Estimated Power Consumption 560 Watts
speakers _ JAMO s426 hcs3
Response Bandwidth 48 - 20000 Hz
Crossover Frequency 2500Hz
Connectivity Technology Wired
Max (RMS) Output Power (Total) 600 Watt
Detachable Grilles Yes
Nominal Output Power (Total) 400 Watt
Maximum Power Output (Watts): 140W
Frequency Response: 48Hz-20KHz
Sensitivity 89 DB
Surround Polk fxia4
•Power rating: 20W - 150W recommended amplifier power
•Nominal impedance: 8 ohms
•Tweeter: Two 1.0" silk polymer-composite dome cone tweeters
•Midrange: One 5.25" driver / Polymer composite dynamic balance with rubber surround
•Cabinet design: Vented enclosure / Acoustically inert 0.75" MDF cabinet
•Mounting options: Integrated keyhole slot for wall mounting
Additional Specifications
•Frequency response: 50Hz - 27kHz / Lower 3dB limit: 60Hz / Upper 3B limit: 26kHz
•Efficiency: 88 dB
•Terminals: Gold-plated 5-way binding posts
•Acoustically inert stamped driver basket
•Floating anti-diffraction grilles
SUbwoofer polk audio PSW10
Amplifier Power Output 50 Watts
Frequency Response 40Hz - 160Hz
Impedence 10 Ohms
lastly the...
Polk cs1000p
Power Range
Loading... 20-250
Sensitivity
Loading... 92 dB
Impedance (Ohms)
Loading... 8
Frequency Response
Loading... 45-25k Hz
now i was wondering with all the listed specs for each. would this be a great match together? would my reciever be working over time etc.. the technical stuff not so knowledgable so if anyone who reads my post hopefully you can shed some light on the technical jargon for me. on why...they yes would go good or no! thanks for reading!
Now its off to vegas for me babyee...ill keep my eyes open though. bringing the laptop. I sure well have down time to get to a lappy and check out this thread. :spend:
Channels 7.1
Sensitivity 89 DB
Surround Polk fxia4
•Efficiency: 88 dB
Impedence 10 Ohms
lastly the...
Polk cs1000p
Power Range
Loading... 20-250
Sensitivity
Loading... 92 dB
Impedance (Ohms)
Loading... 8
Frequency Response
