Hi everyone, glad to be posting my first item on this awesome forum
I've got a pair of Vifa 10" PL26WR09 4ohm drivers which were to be used for a floorstanding 3 way speaker which didnt materialize. So now that I have them sitting around, I'd like to use them as subwoofers for my modest home theater if possible.
At the moment I'm using a pair of old 8" Yamaha YST-SW90 which are fine but they just dont go low enough. I'm thinking that these 10" each in a 2.8cf box tuned to about 22Hz might do the trick. I'd keep the crossover around 50Hz or so.
I'm wondering if there would be any reason not to use those drivers in a smaller room if my listening levels and bass requirements are not very excessive? Is the only real difference between my drivers and a proper 10" subwoofer the ability to play louder and take more abuse? At modest sound levels, would they both sound just fine or will a true subwoofer be cleaner and more accurate?
By the way I'm going to be powering it with my old Soundcraftsmen PM860 power amp which is rated for 300w RMS per channel into 4 ohms and as a crossover, I will use my AudioControl Phase Coupled Activator.
I realized that specs for the woofers might be nice too
FS 26Hz
QTS 0.35
QES 0.38
QMS 4.49
VAS 110L
LE 1.7
RE 3.2
Xmax 8mm
BL 8.7
VC diameter 50mm
moving mass 55g
FS 26Hz
QTS 0.35
QES 0.38
QMS 4.49
VAS 110L
LE 1.7
RE 3.2
Xmax 8mm
BL 8.7
VC diameter 50mm
moving mass 55g
