1 - 2 of 2 Posts
Relatively new member - superb forum and discussions.
I am using REW (great tool) for Room EQ and Speaker Building. The speaker building workflow is fairly straightforward. If possible, would very much appreciate feedback on what workflow folks use to commission a new HT multichannel system. I get called upon by friends, etc. to do this - most folks are fairly clueless, so even basic improvements yield good results. Assuming workflow parameters include:
- basic system commissioning (set up checks, initial speaker placement) - maybe some pre-calulations on what to expect, modes, etc.
- initial response testing - optimiziong speaker placement
- room amendments (absorption, diffusion) - where this is possible
- fine tuning, receiver EQ curve applications
etc.
Welcome feedback on the approach you use - thanks in advance. If there is a workflow guide I;ve missed, appreciate a link.
JRP
1 - 2 of 2 Posts
