G
Guest
·Hello,
I am looking to build a sub enclosure for my 5.1 surround setup I am doing in my living room. Basically I would like it to compliment my Infinity Primus setup so far but I only have about $400-$500 to do so. I was looking at the Shiva-X and a BASH 500 but I got to thinking... I have a few JL Audio 10w3 d4's laying around that I pulled from my truck a few years back. I had 3 of them on a Phoenix Power XS2500 (2ch amp w/ 500w RMS rating at 12v) and loved them immensely. I can always upgrade the sub later if need be but would like to start with something I have on hand if possible. I am used to building small sealed enclosures for car audio setups and especially what I called the 3/2 rule (where you put 3 subs in the same airspace you can build the enclosure for 2 and have proper airspace). It worked wonders on my 3 JL's. Although I would rather build a home theater sub with just one or two as I have a use for the other one in one of my MR2's that will finally be running again soon.
My main question is this... If I were to build an enclosure to fit one of the 10w3's in would it be better to go with a sealed or ported design given the use will be in the home now? Or should I just spend the few extra dollars and get the Shiva-X like I was planning before?
A little background info is this: My room is approx. 18x20 and has a vaulted ceiling that peaks about 10ft. I am trying to compliment my Infinity P362 fronts, PC250 center, and CS60 in-wall rears. We do about 90% tv/movies and about 10% music. If I left out any details that are needed to give an educated guesstimate please let me know.
Thanks in advance!
Thanks in advance!
