1 - 8 of 8 Posts
I am new to this aspect of Audio EQ. While I have set up my HT using Audyssey EQ XT I would like to control the bass region more tightly.
I already have a RS SPL meter, so would these hardware additions be OK ?
a) DSP 1124
b) Beringer UCA 202 USB Sound card
Both avail from Parts Express
Alternate Sound Card : Creative SB X-fi 5.31
I will also need various adapters which I will purchase from Monoprice.
I would like your comments before I go and purchase them
I will be using a Toshiba Laptop with Vista OS
Thanks
To make sure I buy the correct cable from Monoprice for the BFD ... Is it XLR Male to RCA or XLR Female to RCA. TKs
Discussion Starter #5
If you're talking about for the BFD, you don't need any XLR cables. RCA to 1/4" mono (TS) will do.
Yes , BFD. Also I assume I get the mono not the stereo 1/4 to RCA. I hope to find 1/4" to RCA female to avoid another coupler !
Discussion Starter #6
I have read the instructions for REW but unclear at which point the RS SPL meter Correction file is to be added to REW . Surely it must be incorporated befor any measurements are taken.Tks
That would be in the Mic/Meter tab of the Settings. Use Browse to select the file wherever you have downloaded it to your system.
Bill
Discussion Starter #8
Thanks ... found it .
1 - 8 of 8 Posts
