1 - 2 of 2 Posts
My TV started having issues for about a year where it would suddenly turn off. At the beginning you could simply turn it back on and it'd work for awhile. As time went on it got worse and for a while you could leave it for a couple days and come back and it'd work for hours. But about a month ago it stopped working completely.
I did hold the menu and input button and the green light blinks 1-2.
Any advice is greatly appreciated. The wife wants me to through it out and get an LCD but I know it's something simple like a fuse.
Thanks.
Hello, haymel69!
Where did you find instructions for that button sequence? The manual's troubleshooting section does not list it (see pp. 74 & 75). Also, if the TV is truly dead, then no combination of button-presses will fix it. Does the power indicator turn on/off when you press the power button?
1 - 2 of 2 Posts
