1 - 2 of 2 Posts
My TV started having issues for about a year where it would suddenly turn off. At the beginning you could simply turn it back on and it'd work for awhile. As time went on it got worse and for a while you could leave it for a couple days and come back and it'd work for hours. But about a month ago it stopped working completely.
I did hold the menu and input button and the green light blinks 1-2.
Any advice is greatly appreciated. The wife wants me to through it out and get an LCD but I know it's something simple like a fuse.
Thanks.
Plain ole user
It has been many years since I worked on these. First step is to find out what the code means. If I recall, 1-2 means that the system is not in shutdown. Could be you have a 2-1 code? It can be hard to tell. Regardless, find a manual or guide for the codes first. That may point you in the right direction.
My first thought would be to look for bad solder connections, swollen capacitors. These would be the obvious things that you can visually find that might result in that kind of failure.
1 - 2 of 2 Posts
