I have begun to have an intermittant problem with my 65" RPTV.
The issue is one of blue halos and blue 'smearing' to the right. When the problem happens, the screen will flash and jump a little, then go away. Strangely, it does not happen all of the time.
Movie inputs from the DVD or direct TV feeds seem to lead to the issue after the set is warmed up. However, sports feeds (sunday ticket, local hi def, non hi-def soccer) do not cause the issue after hours of display time.
I have all sources fed into the 1080i component input of the TV through a switch box. I have isolated sources/cables directly to the 1080i input to rule out the switchbox, but I have not yet tried to make the problem occur on the 480p inputs.
convergence seems to be functioning properly
Any thoughts?
Any thoughts?
