1 - 3 of 3 Posts
Ws-65819 error code 24
So I go to watch a game last week and turn on the set. Power light comes on then goes off.
After some research I do an error check and it give me 24. It is a vertical deflection failure.
So more research and I get a set of convergence chips, resistors and fuses from a reputable online source. Sanyo stk.
Put these chips into place and checked all of the related resistors and pico fuses. They were good.
So I started it back up, same symptom, same code.
Anyone have more ideas before I call for the 'pros'?
There were two additional pico fuses on the other board that I did not check...should I bother?
thanks,
R
Plain ole user
2-3 codes indicate a deflection failure, not necessarily vertical. Convergence is something different and failures there usually produce 2-2 codes (short detect on low voltage supplies).
You can certainly check the other fuses, but you really need to troubleshoot a deflection problem. If you don't understand the difference between convergence and deflection, you probably should consult a professional. There is no single common symptom-repair relationship for a 2-3 error. You could check the larger output transistors for a short, and look for obvious problems, but if you are not familiar with TV defelction circuits and troubleshooting techniques, you probably need some professional service.
1 - 3 of 3 Posts
