1 - 11 of 11 Posts
I got this set free a few years back. It had the convergence problem when I acquired it. I fixed that up. Now the picture stays very bright at startup for anywhere from a couple seconds or for the duration the set is powered on. If I wack the top of the cabinet, it sometimes will revert back to normal color. Sometimes it will go all day without going bright and other days it is constantly bright.
I had it apart numerous times and it fixes it for a week or so. I think it's a bad connection on one of the boards, but I can't see any cold solder joints when I pull them for inspection.
I did remove the front access panel and if I reach to the right of the blue gun to the signal board, the vertical card there is accessible. If I flick it, I can change the state back to normal. I can't say it's this particular card or the vibration may affect the failing component indirectly.
Discussion Starter · #4 · (Edited)
brightness.....
normal after flicking card.
The card that returns things to normal is the card behind the green/yellow stripe wire (3DYC)....
I'll have to check this again when I get home from work, can't see pictures. It does sound like we might have the same issue. Maybe I'll try giving it a whack when I get home. Also I want to see if the front panel access like you said, I want to try what you did and see.
I'll have to get pics up of mine too. But once I see yours I think I'll know whether we have the same issue. Either way, if you figure it out, let me know! And I'll do the same. I desperately want to fix this so I can enjoy some movies.
Plain ole user
Look for cracked solder joints on the signal board, on the upright board, and look for coolant spills on the signal board.
I think I narrowed it down. Connector RM. Still doing some testing. The connector is about 1-2 inches from the upright card. It has a pair of black and white wires that feeds each light CRTs. The blue CRT also has a brown feed to it. I don't have a Service manual for the 55809, but the one for my 55511 shows it as R out, NC, GND, G out, GND, B out, GND, IK. I don't know what IK is. If I move the ferrite collar, I can get it to toggle the state (bad to good and back in rapid succession).
Pins 1, 7, & 8 have bad solder joints. Pin 8 is IK and may explain the problem. Now if I can find my butane.....
1 - 11 of 11 Posts
