1 - 1 of 1 Posts
X-Rite's i1Diagnostics 4.1.2 Released @ 18 February 2016
i1Diagnostics allows you to test your X-Rite measurement instrument functionality and update licenses on your device.
Use of this application by end users is recommended when problems are experienced with the measurement instrument.
i1Diagnostics creates a report which can be sent to X-Rite support for further investigation if problems persist.
Supported instruments:
- i1Pro
- i1iO
- i1iSis
- i1Display 1 & 2
- ColorMunki Photo & Design
Bug fixed: Connection issue with i1iO on OS X El Capitan (10.11)
Download Link: http://www.xrite.com/i1diagnostics/support/d1607
1 - 1 of 1 Posts
