1 - 15 of 15 Posts
I was looking at the necessary components to begin measuring my system and saw that the recommended mic preamp is the XENYX 802. I was browsing Behringer's website and came across the XENYX 502 which appears to be able to do the things we need. The price is also $15 less. Is there any reason that the 802 is specifically recommended over the 502? Is it because of the highlighted text below in the 802's description?
XENYX 502
Premium 5-Input 2-Bus Mixer with XENYX Mic Preamp and British EQ
- Premium ultra low-noise, high headroom analog mixer
- State-of-the-art XENYX Mic Preamp comparable to stand-alone boutique preamps
- Neo-classic "British" 2-band EQ for warm and musical sound
- Main mix, stereo CD/tape plus separate headphone outputs
- CD/tape inputs assignable to headphone output or main mix outputs
- High-quality components and exceptionally rugged construction ensure long life
- Conceived and designed by BEHRINGER Germany
XENYX 802
Premium 8-Input 2-Bus Mixer with XENYX Mic Preamps and British EQs
- 2 state-of-the-art XENYX Mic Preamps comparable to stand-alone boutique preamps
- Neo-classic "British" 3-band EQs for warm and musical sound
- 1 post fader FX send per channel for external FX devices
- 1 stereo aux return for FX applications or as separate stereo input
- Main mix outputs plus separate control room, phones and stereo CD/tape outputs
- CD/tape inputs assignable to main mix or control room/phones outputs
EDIT: Nevermind, it looks like the Main mix outputs are all that is necessary??? This is all very confusing! Haha.
Yes there is. IIR, the 502 does not have phantom power. That's a must-have in order to use the recommended measurement microphone.
Hi Wayne,
It appears that the 502 model does indeed have +48v Phantom Power. It is on their site here just below the image of the product:
(Unfortunately I'm too new to be allowed to post links)
"And with the new addition of +48 V phantom power, the possibilities are even greater."
Interesting, yet they still show the 502 without the phantom on/off switch and light in the photograph.
But, it does say they've added it (something that should have been done long ago).
I nominate Dave to purchase one and verify if it actually has phantom voltage.
Has anybody verified if 502 can be used instead of 802?
This will save me couple of dollars.
Thanks
Puneet
Yes. The website had all the necessary info (current model has phantom power, how it functions, there is no phantom power switch or indicator, etc) for me to make the purchase. Works great contrary to some of the incorrect info being posted here :T .
I just got a 502 and the box says it has phantom power but there's no switch for it & nothing in the manual says how to activate it.
I also checked Behringer's website and can't find any info there. I e-mailed Behringer but have not yet heard back. Meanwhile, one thing I found on the web seems to indicate that the XLR input automatically has phantom power, so I presume I just plug the mic in there and it works.
Is that right?
Thanks,
Mark
Yes, new 502's have phantom power that is always on, that should work just fine for you, as other people here have used them with no known problems.
I have the 502 and one problem I have with it is that I must turn the main mix volume up in order to turn up volume on the headphones (unless the signal is coming in through the CD/Tape input). I would like to be able to turn up the headphone volume for signals coming through the regular line inputs without having to turn up the main mix volume. I'm wondering the the 802 allows this? Does anyone know because I can't seem to find an answer to this anywhere online. Thanks.
The switch on the other mixers turns the PP on and off; with the 502 it's always on.
I read in the manual some warning to not connect mic while is phantom power is on...
As with 502 is always on / there is no switch to turn it off/on , is that "healthy" for the mic (ecm 8000) ?
As I know lot of people uses B 502 / ecm 8000 but I'm still a bit confused with this combo...
1 - 15 of 15 Posts
