1 - 5 of 5 Posts
Hello,
I intend to invest onto a DSP Room correction equipement from Xilica for use at first with 2 channels input and crossover filtering for bi-amp to 4 outputs. As second step I'd like to also have extension capabilities up to 4 input channels.
REW is clearly designed for use with DSP Xilica XP-2040.
Can a XP-4080 be also used with REW ? Is there any limitation ?
Thanks
I have the Xilica 4080... I don't see any reason why you couldn't use REW with it.
I work for Xilica doing their support for North America. The XP4080 is identical in every manner to the 2040 apart from the additional channels.
Kent
Discussion Starter #4
Kent,
Thanks so much for precisions, this was somehow what I was suspecting
Any idea where I could find XP4080 (or XD4080) second hands units at reasonable prices in Europe ?
I had one in my radar in US, but imports and VAT prices makes it un-reasonable.
Regards
Kent,
Regards
You might also want to look for one as a B stock item...sometimes you can get a real good discount.
1 - 5 of 5 Posts
