1 - 11 of 11 Posts
two choices: which is best
*Belden 1800F Balanced Audio Cable
(AES/EBU, low-capacitance, high-flex cable)
*Canare L-4E6S Star Quad Balanced Audio Cable
(Higher noise rejection, but with higher capacitance)
what are the trade-offs , id klike to know the differnce between 'low-capacitance'
and
'Higher noise rejection, but with higher capacitance'.
what the differnce an what the effect of each on sound an performence
___
which should i get, iv got the outlaw audio 976 receiver with 4v - 9v output via xlr preouts
currently connecting to my four Crown xli 800 im using one for each set of my speakers
fronts , center , sides , backs , aan to my Xls 1502 for my subs
my current xlrs that im using are the
____
Monoprice 3 Meter (10ft) 3-pin DMX Lighting and AES/EBU Cable
are these good enough or should i get some from BLUE JEANS an if so which
one would be better
I doubt if you will discern any differences aside from the price and appearance.
  • Like
Reactions: Sal1950
ok , but do you know the meaning of
Sure but you can look them up. I have spool of the Canare that I use for construction projects.
The higher capacitance of the Canare can roll-off highs but, with short domestic runs, it will not effect audible frequencies.
AES/EBU refers to the use of the Belden for digital signals where a high-frequency roll-off (above audible frequencies) can be a problem.
Discussion Starter #6
? Canare can roll-off highs could remove any distorion that might ecurr from my outlaw audio 976 receivers 4v - 9v preouts connected to my xli 800 , ive offen wondered whats the max volt input to the xlr inputs on my xli 800 because i dont know , both the selectable input sensitivity of 0.755V or 1.4V are low then 4v but does the mean that they cant take higher then or does that mean that the point at which the amp gets a reaction to the singnal
1. I doubt if there is any audible roll-off with such short lengths.
2. Using a cable to fix distortion is not a fix.
3. I can't parse the rest of your post.
Oh..................
4. I agree with Wayne that you will not hear a difference among these cable options.
1 - 11 of 11 Posts
