1 - 5 of 5 Posts
Hi my old XP laptop has no adjustment for the sample rate 44.1, 48khz in Sound (playback and record) in control panel.
I use a UMIK mic.
Is this a problem?
If i had a outboard Pre/soundcard and XLR mic would this be a problem or solve this?
Thanks in advance
From what I understand, the extension of the high frequency measurement can’t be more than double the sampling rate. So that’s 22 kHz with 44.1 or 24kHz with 48. Either way you’re beyond 20 kHz. :T
Thanks Wayne
Is there any need to change these settings when using a external Pre / Pro soundcard?
When using the USB mic which setting would i use in REW 44.1 or 48khz, don't i have to keep them the same?
Not having any adjustments and with Windows settings + age of computer i suppose it would be 44.1khz?
1 - 5 of 5 Posts
