I don't know this amp, but if it is a class a, b or ab output stage you could look for the following problems which can occur.
1) It could be a problem with the relay contacts of the protection circuit which is in series with the speaker output terminal.(bad contact)
2) it could be a problem in the protection circuit itself, i have seen sometimes a bad electrolytic condensator in this circuit.(look for short sleeve)
3) It could be that the DC output voltage on the bad channel is a lot higher as from the other channel. (check / adjust output offset voltage)
4) It could be that the socalled bias current in the output stage is low.
I hope this info is giving you some help on this issue.
Succes anyway.
mollie
