1 - 3 of 3 Posts
I have a Yamaha Advantage RX-A 3050 that uses YPAO, not YPAO R.S.C. I will be setting up my Home Theater as an 11.4 configuration with all Klipsch speakers and subs.
In researching your recommendations I can see how the miniDSP 2X4HD would be a good tool to set up the four subwoofers. From what I can see that setup from the receiver seems very straightforward.
I noticed in reading your articles that 2X4HD/DDRC-24 and/or nanoDVR HD would be an excellent addition to setting up my speaker system further after using YPAO. I have done a lot of reading and for the life of me I am having difficulty in how to set up the hardware if I even need it.
The UMIK-1 seems simple enough but setting up the miniDSP 2X4HD with DDRC-24 or the nanoAVR HD is somewhat confusing. Remember, Baptist Pastor - Bible is not a problem and I am getting the hang of some of the audio but I really have a lot of learning to do.
I would like to know what the best setup might be with my receiver.Would it be good to use the UMIK-1 with REW to tweek the system after using YPAO?
Since the 2X4HD has a Toslink input I am wondering if that is the best way to connect everything from the Yamaha. The Yamaha does not have RCA jacks for every speaker output to connect to the 2X4HD unless I am missing something. I do realize you cannot connect every speakers' output to the 2X4HD at the same time via RCA.
Obviously, I realize I can only work on two speakers at a time while using the 2X4HD.
The bottom line is I am essentially trying to tweak my 11 speakers after running YPAO. Then use the 2X4HD for the subs.
I would need to know if DDRC-24 or nanoAVR HD would even be beneficial to me.
God bless you all,
Pastor Greg Heenan
Unity Baptist Church
Baton Rouge, LA.
In my opinion the MiniDSP NANOAVR DL is the way to go... with the HD series all your getting is room EQ / Xover / ...with the Dirac Live series your getting a whole new world of room optimization - all of which is done for you with just a microphone and an hour of your time...
1 - 3 of 3 Posts
