I was reading through the gain structure article in this forum and noticed a reference to my very own DEQ - the Yamaha DEQ7 (picked it up for $30 at a Music Go Round).
Now, it was mentioned but not really explained what my optimal gain structure should be for an older piece of equipment like this. There was lots of talk about not needing to max out gains for 24 bit DEQs, but when the DEQ7 was mentioned, it sounded like I should be maxing out signal levels (assuming no clipping). For those of you not familiar with the DEQ7, it has an input gain control knob, input level selector for +4/-20 dB (yes, -20 not -10) and an output level selector of +4/-20 dB. My chain of equipment and gain structure is as follows:
Pioneer Receiver LFE Output (0dB) -> DEQ7 Input (-20dB) -> Input gain dial maxed out->DEQ7 Output (+4dB) -> AudioSource Amp100 at 50% (bridged).
I use the +4dB on the output stage of the DEQ because the Amp100 states an input sensitivity of 1.4 V (+4 dB). I am running an Anarchy Tapped Horn off of this system, and if I get real close to it I can hear the noise.
My question is this: Am I better to run my gains at maximum until the last stage (volume control on the amp)? Or is there another way I should set this up? I can still turn up my receiver's LFE output to +10 dB, and in doing so see no clipping at my usual listening levels. Thoughts?
The only scenario that (subjectively) lowers the noise seems to be:
Pioneer Receiver LFE Output (+10 dB) -> DEQ7 Input (-20dB) -> Input gain dial maxed out ->DEQ7 Output (-20 dB) -> AudioSource Amp100 at setting to hit SPL desired
